KRM
offer a wide range of flail mowers to suit all applications. With
cutting widths from 1.3m right up to 6m folding machines and collectors.
KRM
Cat
Ideal for
the smaller tractor the Cat is the smallest of the KRM range.
The Cat starts from just 1.35m and is available up to 2.1m. With
its twin position headstock the Cat can be used either in line
with the tractor or offset to one side. As with the rest of the
range it features a full width rear roller, End skids and a PTO
free wheel which allows the machine to wind down and prevents
any shock loadings.
KRM Condor
The Condor
is a versatile flail mower for pasture topping, set-aside, parks
and gardens, and ideal for field margins. The low weight and power
requirement of the Condor make it suitable for use with a small
tractor. The headstock of the Condor incorporates a 40cm hydraulic
offset enabling the machine to work around trees or poles. In
heavy crop conditions the rear cover can be lifted to reduce the
power requirement, this also facilitates easy flail maintenance.
Leaflet |
KRM Unika
This multi purpose, heavy duty flail mower, is capable of handling higher volumes of material and is ideal for pasture topping, set-aside, verge mowing or for the maintenance of field margins. The Unika can be front or rear mounted and features hydraulic side shift allowing it to operate in line with the tractor or offset to aid cutting under trees and around obstructions. |
Specification |
Leaflet |
KRM Zenit
The Zenit
is a heavy duty flail mower for larger areas of set-aside, pasture
topping, roadside verges, orchards and bridle ways. Its compact
and low profile design together with its 60cm hydraulic side shift
allow the Zenit to cut close to field boundaries and around obstructions.
Available from 1.6 to 3.0m all Zenit machines are fitted with
a high power gear box, double skin and robust drive line to give
hassle free mowing.
Leaflet |
KRM Zenit
Avant
The Zenit
Avant is equipped with a double head stock allowing it to be front
or rear mounted. It features the same driveline as the Zenit except
for its 1000rpm PTO drive. The Avant is available in widths from
2.1 to 3.0m. Like the Zenit the Avant is fitted with a replaceable
wear sheet to prevent damage to the hood and increase the life
of the machine. For safety reasons the rear off the Avant is sealed.
Leaflet |
KRM Icon
The latest addition to the KRM range of flail mowers this high output machine with tall front opening or "mouth" and unimpeded material flow is capable of shredding large volumes of material, making it ideal for all tasks. Chopped material is deposited over the rear roller eliminating the risk of blockage. Single and double headstock versions are available in all widths from 2.3m to 3.0m. Hydraulic side shift is standard across the range. |
Specification |
Leaflet |
KRM Kronos
These heavy
duty machines with castor wheels for height control are ideal
for cover crops, straw chopping, stripped straw and rape stubble as well as
pasture and set-aside mowing. Available from 4.8m to 6.4m wide
as a rigid machine or as a 6.0m folding machine. With their 200hp
drive line these machines are capable of terrific daily work rates. |
Specification |
KRM Pellicano
Specially
designed for universal use the head of the Pellicano can be operated
in line with the tractor or offset for verge maintenance and field
boundaries. The pivoting head has a full width roller to follow
ground contours and can be operated from below horizontal for
banks and ditches, to vertical to trim hedges and small trees.
The Pellicano features an offset of 1380mm, is available in 1.6m,
1.8m, 2.1m widths and can be specified right or left handed.
Leaflet |
Super Pellicano
Like the
Pelicano, the Super Pellicano is also ideal for general farm use
and verge mowing. With its greater offset of 1780mm the head can
be put fully outside the tractor wheels meaning the area to be
cut hasn't been driven over. When cutting ditch sides this also
keeps the tractor further from the edge. The Super Pellicano is
available in 1.6m, 1.8m, and 2.1m widths and can be specified
Leaflet |
Pellicano Master S
The Pellicano Master S is the heaviest duty offset flail. Cutting heads up to 2.5m are available and the same wide offset (1780mm) comes as standard. Break back protection is provided by a spring loaded break back on the lower link and cut material is deposited behind the rear roller. These machines are available in 1.6m, 1.8m, 2.1m and 2.5m cutting widths and can be specified to be right or left handed.
Leaflet |
TLF
Heavy
duty verge mower for the professional featuring universal cutting blades for grass, brambles, small bushes etc on road sides or ditches. Available as front or rear and left or right handed, the machines cutting head can be adjusted from 90 degrees vertical to 70 degrees below horizontal. A gas accumulator allows the cutting head to automatically follow ground contours and a fast acting side shift moves the head through 60cm to avoid obstructions. |
Specification |
Collector
Mowers
Our range
of collector mowers includes 3 models. The Jolly is for tractors
from 40 - 70hp, the Sole (pictured) if for tractors from 70m
- 90hp and the Vortex is for tractors from 90 - 140hp Incorporating
heavy duty hammer flails, large diameter rear roller with scraper
and internal wear and tear sheet. Ideal for playing fields, parks,
golf courses or larger grassed areas.
Leaflet |
