KRM
offer a wide range of power harrows from a 2.5m Maxim through
to a 7m folding Magnum
KRM Kratos
The KRM Kratos power harrow is available in widths from 3 to
6m and features a 200hp gear box (250hp on folding models). Other features include quick
release blade system, SKF taper roller bearings, automatic torque
clutch, heavy duty headstock and support frames. |
Leaflet |
Specification |
Gallery |
Features |
KRM Maxim
Special
The Maxim
Special comes in a range of sizes from 2.5 to 6m. Changing the
gears on this 190hp machine gives rotor speeds of 313rpm or 359rpm
at a PTO speed of 1000rpm. Standard equipment includes 21z shaft
with friction clutch protection and quick fit blade system.
KRM Magnum
Special
The heavy
duty KRM Magnum power harrow is available in widths from 3 to
6m and features a 250hp gear box. Other features include quick
Gallery |
Standard Features
All KRM power
harrows benefit from the same standard features. All have 4 rotors
(8 blades) per meter giving a finer tilth and easier driving,
this configuration also ensures both outer rotors turn inwards
reducing ridging between passes. Top quality SKF taper roller
bearings are used for rotor support requiring no additional greasing
and offering exceptional reliability. Centrally mounted gear box,
rear clod bar, and twin position floating lower links are all
standard. All our power harrows have heavy duty head stocks making
them ideal for use in seed drill combinations.
All
KRM Power Harrows feature the same quick fit blade system.
Each blade can be quickly and easily changed by removing
a single pin. Significantly reducing downtime for increased
productivity.
