Sow
with outstanding uniformity |
KRM
Ares-P Tine Drill |
This recently introduced model utilizes a new pressurised hopper and metering system with full ISObus control. Its available as a solo drill or with an integrated cultivator and comes in widths from 4m to 6m. Heavy duty Elite tine coulters make this drill ideal for plough
based or Min-Till applications. |
Features |
Specification |
Gallery |
Leaflet |
KRM
Ares 2713 Tine Drill
Heavy duty Elite tine coulters mounted in four rows (3 rows on drills with integrated cultivator) make this drill ideal for plough
Available in
4, 4.5, 4.8, 5 and 6 meter working widths. The Ares can be used
as a solo drill or fitted with a cultivator for increased versatility.
Features |
Electronics |
Gallery |
Leaflet |
Specification |
Double Disc |
KRM
SP-M Drill
This recently introduced model utilizes a new pressurised hopper and metering system with full ISObus control. Available in widths from 4m to 7m, the SM-P can be used direct or in min-till seed beds. The four wide stagger rows of carbide tipped SM tine coulters create a narrow tilth strip, clear of crop residue. |
Features |
Specification |
Gallery |
Leaflet |
KRM
1909 Drill
This new concept
drill offers cereal growers the opportunity to use only one drill
for sowing into a ploughed seedbed, into min-till prepared seedbeds
or direct into a stubble. Four rows of carbide tipped SM tine coulters create a narrow tilth strip, clear of crop residue. |
KRM
A6000 Drill
Available with the choice of Elite tine coulters for plough based and min-till seed beds or SM coulters for min-till or direct work. This high capacity, high output trailed version of our tine drills is capable of huge daily work rates. |
Features |
Electronics |
Gallery |
Specification |
KRM
2512 Combination Drill
This combination
drill is suitable for power harrow or cultivator mounting and available
in 3 and 4 meter working widths.
Close coupled
for reduced lift capacity, with offset metering unit for easy calibration.
Three rows of
heavy duty Elite tine coulters provide more clearance and
greater pressure than traditional Suffolk coulters, this eliminates
coulter bounce allowing higher forward speeds and giving better
penetration in tough seed beds. |
KRM
Trisem Box Drill
Available in
3, 3.5 and 4 meter working widths. The Trisem can be used as a solo
Heavy duty Elite
tine coulters mounted in three rows make this drill ideal for plough
based or Min-Till applications. These coulters have extra clearance
for Min-Till or conventional seedbeds and extra pressure for positive
penetration and reduced coulter bounce at higher forward speeds. |
Specification |
