Spread from
12-36m without changing discs, vane position, height or tilt.
The only adjustment is that of the downshutes and PTO speed. With
capacity's from 1.4 ton up to 3.0 ton there is a machine to suit
all farm sizes. These machines can be computer controlled to facilitate
GPS and variable rate work.
The SG has been specifically designed to handle more difficult bulk materials. Its single wide floor belt enables it to handle products such as lime and rock salt as well as fertiliser.
ISOBUS and Section Control come as standard on this machine designed specifically for fertiliser. The F Series features independently controlled twin floor belts and the flow of fertiliser on to the disc's is controlled by independently adjustable downshutes.
Adapted for spreading lime and salt. The disc's of the SG are driven from the top by hydraulic motors, this allows the disc's to be mounted closer to the ground and their speed to be adjusted
